Hi Folks,
I'm working on a Formula 233 from 1972. It has, I believe, a Mercruiser 888 or something similar but perhaps earlier. Ford 302 V8, engine is not marked "Mercruiser" anywhere but it is an 888 Outdrive. Has aftermarket aluminum valve covers marked "Powered by Ford"
I am putting it back together and I can't get the timing right.
First, I pulled the valve cover and located TDC by feeling the top of the piston on the #1 cylinder with a chopstick through the spark plug hole (starboard side forwardmost, the cylinder closest to the belts on the bank furthest forward) and verifying that it was the right stroke by looking at the valves. TDC by my measurement was about 35 degrees advanced of where the original mark on the harmonic balancer is. I checked it 3 times; the 0 mark on the balancer is halfway into the firing stroke for #1. Dunno how that happened but whatever.
I put the distributor on and ran the wires following a diagram I found for the Ford 302 and my Clymer Merc manual, 1-3-7-2-6-5-4-8, counter-clockwise. No go. Couple front fires through the carburetor. Then I turned the distributor to line up #1 with where the mark on the balancer was. Still nothing. I've tried the wires in the opposite order, double checked everything, twisted the distributor a little ways one way and the other way... can't get it to go. I have good spark at the cap and the plugs, I have fuel. Its still out of time.
Any tips on how to get it in time?? Am I missing something? Once I get it running I'll put a light on it and dial it in, but I can't even get it to fire.
Thanks!
Thanks!
