The plastic ring under the timer base should be lubed with a white lithium grease. It's pretty slippery, even down to cold temps. Don't use a heavy wheel bearing type grease. After the engine has run for a while, I'd check the cyl head temps with a laser temp gun. The heads should idle around 143-150 degrees. If one is running significantly lower temps, you may have a thermostat that is stuck open. A cold-running head will not have clean combustion equal to the warmer head. Plugs can accumulate carbon and appear darker.
