I have a 1976 85 HP Johnson on our 24 foot pontoon, motor had been sitting for a while so I cleaned the carbs checked the foot oil checked the plugs. Put the muffs on and it would not slow idle and it would and still does backfire through the exhaust at no certain time. Went to the lake, and the only way to make the engine stay running from idle to shift into gear, was shut the fast idle down and very quickly push into gear before engine died (hard to do but no gear grinding).
The engine would never open all the way up, it seemed to run a little past 1/2 WOT. The engine would backfire but stay running as we ran a little over wake speed, no need to try open it up, pontoons don't go fast, at least this one didn't and won't. It was tough getting back on the trailer because the engine just didn't have enough power to shove the boat on. Burned 5 gallons gas in 4 or 5 miles, black oily junk dripped from prop area, wasn't gear oil.
Ran a compression check 92 PSI on all 4 cylinders, changed plugs, replaced the carbs, changed out two coils, changed one plug wire end as it was extremely rusty. Motor will slow idle and runs much better now but it will still backfire through the exhaust. I plan to replace the power pack today and see if that does any good, also will make sure plug wire ends are letting spark get to plugs correctly.
I have read for several hours here on Iboats trying to find out about this problem, hopefully someone will know what the problem is.
