Just bought used OMC controls from Ebay. I have a 1986 30hp outboard. The controls are black with 2 control cables and one power cable with red plug. There are also two other plugs hanging of of power cable. This is what I dont get. My motor has on one side a lever for the forward and reverse. The other side is the throddle assembly. Now the control lever with the red button will move one cable back and forth. There is another lever that you pull up on...this will move the other control cable in one direction. When the lever is pulled up, you cant move the throddle lever. How is this going to work on my motor??? Also how do you hook the cranking battery up so the moor will start? It doesnt look like anything would attach to the battery. Help would be greatly appreiciated. Hope this makes sense!!
