Hello Vic and thank you for the info. To further clarify the adjustment screw it appears that it is threaded into the manifold and is accessible thru a hole in the carb base. The screw has a spring behind the head of screw and requires a allen wrench to adjust. Currently the screws on all 6 locations is turned out 5 1/2 turns. The motor seems to run fine just won't idle down idles at appx. 1100rpm?
