Johnson stator help
haz77
Hi,
Im told by the boat yard that my stator is likely to fail anytime since the 2x black pods have cracked & the "insulation fluid" has/is leaking out.
the motor is a 1974 johnson 115hp model 115ESL743 (or B), the black pods have 510839 on them so I take it this is the stator model number but when I ebay / google search this only 3 cylinder models come up with this number?
Mike.
F_R
If by 2 "black pods", you are speaking of the two charge coils on the stator, and goo is leaking out, failure is certain. Heck, they've already failed. You just haven't been stranded yet........(yet).
boobie
You can still get the stator at BRP but it's only $433.00.
Faztbullet
The rectifier is bad or was bad as this overheats stator and coil lamination melts and oozes out....
tblshur
haz77 the part # i have on that stator is 581046 , superceded by 581225 , superceded by 763772 and as FR said 173-1225 . hope this helps:joyous:
