Interesting investigation and a good tip. The blue and green are the rotation sensing wires. The 3rd wire thru the 4 pin connector for the 86 power pack is the kill wire. Black with yellow tracer. Technically, it does come from/to the timer base. On the old single power pack engines with screw terminals, it is a separate wire, screwed direct to the power pack from the control box key switch thru the red plug connector. The 4th wire is the white wire (possible ground?) Not used on the old screw type pack. On the 86 model, wires 5,6 go thru the other two-pin connector and are the power connector from the stator. Your screw pack gets it's power thru terminals 7,8.
