structural1
- Aug 2, 2012
- 34
Those readings on the charge coils were with no DVA. I thought they were too low as well based on the trouble shooting guide you pointed me to and your comments. But I pull it on both pairs 4 times and came up with roughly the same reading. I left the pair connected to the pack and used piercing probes. was I suppossed to disconnect the pack before testing output? Does that make a difference? I tried the DVA adapter on the Orange/Orange Black pair on the Power Coil after getting 46 volts with no DVA. With the DVA and meter still set on 200 I only registered 3.5 volts. So I figured something had to up with the DVA adapter I bought and didn't use the adapter for the Brown Pairs. 46 V without DVA and 3.5 V with DVA sounds crazy on the Power Coil test right?
But even if the 120 V on charge coils is legit.... that only charges the battery right. It shouldn't affect the cranking correct? Thanks so much for the offer on the loaner Pack. But, I wanted to pick up a spare pack anyway. So I'll go ahead and pick one up. Even if it turns out its not the pack I'd like to have a back up.
The pack on it is a CDI 113-6212. I believe the OMC pack part # for a 96 looper 200 is 586-212. Can someone confirm that please?
I of course will keep this post updated on if that solves the problem.
