Make sure you remove the shift rod bolt completely. Not just loosen.
Now, if it STILL does not drop. Flip motor upside down, hang from gearcase about an inch off ground, over a pillow, and spray penetrating oil down drive shaft. Next day, if you have one, hit the drive shaft with an impact hammer type tool.
