Sometimes, not always, when first taking off motor shakes badley, and won't take off { like rev limiter working} If I shut down, trim all the way up for 15 seconds or so, go back down it will run just fine. Also hot light and horn go off for maybe 20 seconds once in a while then clear. New water pump and voltage regulator recently. Appreciate any help.
