Hello all, I am into my first rebuild on a 95 Evinrude 90 crossflow. Things are going well so far but I am a little confused about a couple things. First what is the orientation of the crankcase seal ring gaps? I believe the manual says to face them down but I think Iv'e read on the forum to stager them. Next on sealing the crankcase half's. Where to apply the locktite 518 bead ? I figure around the edges and bolt holes but what about the larger flat surfaces and the fingers that extend to the ring seals and bearings. I know to stay 1/4" away but how do i lay the bead in those areas? I would greatly appreciate your insight
