anderso8623
- May 25, 2012
- 388
Hi Guys! repowering my 1987 Mako with a 78 115 Evinrude. I am wiring the tilt and trim and just wanted to know how to wire it. I think I have a good grasp but wanted to run what I think by everyone and also ask what the mysterious random two wire do. Here we go:
I have three wires from the controls and three from the pump. I have a blue wire on both ends and a green wire on both ends. I have a blak wire from my motor and a red wire from my control. I can assume that the green wires attach to each other at the solenoid and the blue wires attach to each other at the solenoid and the red supplies power and the black is the ground.
How am I doing so far?
Then, I have a separate wire harness that is coming out of the pump that has a black and gray wire (the mysterious wires), I assume these are for the T&T gauge?
Does this all sound correct? Does anyone have a diagram that they could lend me?
Mainly, I need help on wiring the solenoid so I dont blow the pump...dont want to replace that! YIKES!!!
thanks
Jason
thanks
Jason
