1997 Johnson 150 HP, looper with the standard OI ignition, will not stay running.
Turn the switch, motor fires and runs, let go of the key switch and it shuts down.
If you keep holding the key switch in the start position, motor contines to run normally.
Let go, it shuts off.
Tried removing all leads from the key switch (in case switch was shorting kill circuit somehow) and jumped the solonoid with a remote starter switch, does the same thing: runs, then shuts off when you disengage the remote switch.
Just put a new starter in, but ran all day once with no issues, started and stopped several times, so I think it was installed correctly.
Any ideas? Thanks
Any ideas? Thanks
