Freshfish00
- Jul 1, 2014
- 9
I just recently bought a 1959 3 hp motor and I rebuilt the carburetor because it wouldn't stay running for more than 1 minute tops. I did some work on it and got it to run good for a long time, went threw a half tank of gas testing and running it, verified idled was good and fast speed was good also. No here is the problem I had... it got extremely hot started to smoke and eventually quit, i also noticed that the 4 little holes on the shaft didn't have water coming out any longer but smoke instead. Also the back side of the shaft (lower portion of motor that has the prop attached) is now covered in oil. Did I just ruin this motor or is it fixable? Did the water pump burn up? Any help would be appreciated. .....
