I know you need to have equal compression across the cylinders but what SHOULD it be on this motor? Mine is <br />Cly 1 103-PSI<br />Cly 2 101-PSI<br />Cly 3 103-PSI<br />Cly 4 100-PSI<br />Even my math says this is a 3% variance and I keep hearing 10% is OK but any idea what it would have been from the factory? Can you gauge the wear on a motor by the drop in compression?<br />Thanks as always.. Dave
