8hp 4stroke -98 johnson vs 01 evinrude-any difference
litlsea
Hi,<br />I've narrowed down the choice for the kicker on my 21'Glasply. There is a new 98 Johnson 8hp 4 stroke reg. shaft for $1200US and a 2001 Evinrude 8hp 4 stroke reg shaft for $1315 US. Are these basically identical or does the newer evinrude have some upgrade that make it advisable to spend the extra 100 bucks. I can also get the 2000 honda 8hp for $1350 US so it is not really out of the running either. Any advice would be appreciated. Thanks, Jack.
Paul4
Re: 8hp 4stroke -98 johnson vs 01 evinrude-any difference
I'd go with the Evinrude
suzukidave
10 years from now when you go to sell it it will matter that it's 01 not a 98.
litlsea
Hi ,<br />I want to thank you for the advice. Thinking about it, it will make a difference to spend the extra hundred bucks now. I orderred the 2001 evinrude long shaft today. Thanks again!
