Albertafisher
- May 16, 2014
- 2
Hi, I have a 20 hp 2 stroke evinrude. I recently changed the lower unit oil. After my first trip of the year, I decided to change the oil again and found a bit of water as it drained. I noticed that the top drain plug had a oil slick coming down the unit. The plug was tight but not flush with the housing. I checked for cross threading, old gasket and all clear. I attempted to screw the plug back in and it goes tight but not flush. I thought maybe I mixed up the plugs and moved the bottom one to the top with the same results.
Any suggestions?
Any suggestions?
