justinwerner
- Mar 11, 2013
- 12
I need to identify the purpose of this green/yellow stripe wire coming from my control box headed in the direction of my electric bus under the console, but is not connected to anything. Motor starts, runs fine, however there is no power to the bus, so all electrical components connected to the bus wont work without a hot line running directly from the battery. The issue with this is that some gauges remain on because this hot line bypasses the ignition switch. (i.e. the fuel gauge is always on and will drain the battery). Any thoughts? See attached photo.
