Capt'nawsome
- May 10, 2014
- 3
I have a Johnson 9 1/2 hp that has been sitting for years and have been trying to revive it back to life. I have replaced spark plugs , reset points, and cleaned/repaired the carburetor. But it will only start unless I pour mix fuel in. It is getting gas to the bowl and filling it, fuel pump is also brand new. I think it could still be a stuck needle valve and was properly working when I reassembled the carburetor. The lean/rich dial was messed up in the process and was fixed, but not sure.
