I have a 1988 Evinrude 25 (E25RLCCA) that has a case of the hiccups. I just got this engine out and going after sitting for several years. It was put away because of a cracked carb and that is now replace and at the same time I did an impeller, gear case seals, and thermostat. Then engine starts and runs, but seems to have the hiccups. It will run fine for a few turns over then have a backfire, but it will keep running. If I unhook either of the coils and let it run on just 1 cylinder it will idle along and even rev up fine. Any input on what this could be would be great! Thanks in advance!
