davidyoung99
- Apr 2, 2014
- 3
I want to use toggle switches, momentary switch ect to start the motor instead of the key ignition. I bought the manual awhile back and have been using this site as a resource. Im a complete noob at this so please help me out!
The only easy one for me is the "Kill Switch", which when pressed the two M's will connect and cut motor off.'
Im guessing the ON switch can just be a simply on off switch..
Whats the role of the the A or accessory part of the ignition? is it necessary to starting the motor or just for beepers, horns, lights ect. Could I run these accessories on their own switch instead?
The START switch would be a rocker switch but im wondering if I could connect the B and the S wire to it and be able to start it?
thanks for help!
thanks for help!
