Royglastron
- Apr 24, 2012
- 43
Using fresh good battery from truck. Engine and tilt trim motor on boat worked fine when I bought it 2 years ago. Tried just checking the tilt trim motor but nothing. Where should I start to make sure I have a good connection between the battery and the tilt trim motor. New to boats so I am just not sure where to start. Want to check the tilt trim motor first and then go from there to the engine.
Thanks
Thanks
