Im looking for a bit of advice on a 15 hp, Johnson 1995 tiller arm rope start on a little dingy I have in the Bahamas.. It has been really reliable for me for a couple years now, with just some carb problems that is pretty standard with the dodgy fuel we can get.. Last week I was running it as a rescue boat.. I left the dock and had to run a couple miles to the location? Half way there with the engine running great the engine suddenly pretty much dies.. I eventually get it to run in neutral on one cylinder, but really rough.. Looking into it further it will not run on the bottom Cylinder, this is with new plugs. Further more both plugs are firing strong. I noticed some black fuel hose residue in the carb bowl so replaced the hose and installed an inline fuel filter.. I checked the fuel pump screen, and the diaphragm.. I cleaned the carb, really cleaned the carb that is.. and it still will not run on the bottom cylinder.. This is with putting some gas in the spark plug hole and cranking.. Im pretty sure I have ruled out fuel.. I have strong spark, or so it seems anyway on both plugs? So where do I go from here?
- Can I somehow throw off the timing while underway with out hitting anything?
- Does this sound like the mysterious reed valve failure ?
I didn't have a flywheel puller or compression check gauge to diagnose further. Im in the US for the holidays and want to bring back parts and tools and get to the bottom of this. Any help would be much appreciated..
