marcomputers
- Sep 29, 2013
- 3
Hi All,
I'm looking at purchasing what seems to be a clean 1988 Johnson 70HP VRO (disconnected VRO) outboard motor.
Went to look at the motor, we started it up and it ran good on the ear muffs, but only for a minute. Brought a compression tester from Autozone and removed all spark plugs per compression test thread, opened throttle and checked each cylinder. I was surprised to see the compression numbers come in at 85, 87, and 87. Thought they would be over 100.
Spark plugs were dark black when I removed them for the test, which based on the forms would indicate low compression or stuck rings, but it did seem to run strong. I'm obviously worried about the low compression.
The gentleman said that he didn't have any problems with it, other then that it sometimes was hard to start cold. He hasn't run it in a year or so, and it was still pretty cold (only ran for 1 minute) when we did the test.
The only other indication of anything strange was that on the part of the engine block where the ground for the battery goes, paint was peeling a small bit. Only in this location, however, and no where near the head or on other parts of the engine.
He's looking at selling for around $600, but can anyone advise if it is worth it, or what kind of cost will be involved with this engine in the near future based on my tests?
Thanks,
Mike
Thanks,
Mike
