Hi all!
It does so while under load and full throttle. I am able to troll at low speeds but once I ask for more, the bulb eventually collapses.
It is a new EPA approved West Marine 6 gallon tank. I purchased a new old style venting fuel cap with the screw to relieve pressure. Even when I remove the cap COMPLETELY, the bulb still collapses.
There is no restriction in the brand new hose assembly as well. I took off both fittings, pumped the bulb and it blew air out both ends. I was also able to pump gas out of the tank using the primer and no fitting on the outlet. It pumped gas.
One thing I have to mention was that the guy at my local marine supply store said I bought the hose assembly for a Mercury, and not for an Evinrude/Johnson. I had to replace the fuel connector going into the Motor because it would not seat properly and kept popping off. I then took the connector off the hose coming from the internal tank, which I don't use, and it fit securely.
I am lost. Please help me out. I just want to fish!
Thanks!
Mike
Thanks!
Mike
