Re: How to loosen a galled transon screw clamp
I have found that if you heat them & then let it cool down, then repeat this process over say a week or so helps, I also drill a small hole thru the metal around the clamp on the bottom, I then flip the motor on its head so the hole is facing up. spray lube into the hole let set for a day then repeat, heat- cool down -lube
