2003 Johnson (Suzuki) 90 hp 4-Stroke wiring
zeldasage
I have a 2003 90 hp johnson (suzuki) and i hook up the key switch to it amd it wont crank over or do anthing I was wondering if someone might have a wiring diagram for the motor the model # is J90PX4SR
JB
Re: 2003 Johnson (Suzuki) 90 hp 4-Stroke wiring
Unfortunately, Zeldasage, that is copyrighted material. It is in the OEM Service Manual.
However, there are some things that commonly cause that sort of trouble. Does the starter solenoid click when you operate the key? Is the battery fully charged? Is the fuse or circuit breaker on the engine okay? Most of those circuit breakers are resettable by pushing the button on them. Is your control in the N position?
It doesn't sound like that outboard ever ran for you. Is that the case?
