Welcome Guest - Sign Up today
No announcement yet.
1977 Johnson 55 Powerhead Removal
  • 1977 Johnson 55 Powerhead Removal
    Having trouble removing the powerhead on a 1977 55 HP Johnson It appears I have gotten all of the necessary bolts removed. I was able to get the powerhead to lift up about a 1/2", maybe a bit more from from the midsection, but I can't seem to get it completely apart. Am I missing something here?
    Re: 1977 Johnson 55 Powerhead Removal
    Did you disconnect the shift linkage under the lower carb ??
    • #3
      yes I did, I already removed the lower unit completely. seems strange that I was able to get as much space as I have between the powerhead and midsection without it coming completely apart. I can't see anything that seems to be holding it up
      • #4
        Try driving a couple of wooden wedges in the gap once and see what happens. Also shake the heck out of it.
        • #5
          You got the one studded nut from the rear, under the cylinder head?
          [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/forums.iboats.com\/filedata\/fetch?id=9974593&d=1435747884&type=full"**[/IMG2]
          • #6
            If he hasn't got that nut removed, how did he get it raised up from the exhaust housing 1/2 " ??
            • #7
              I came across one once on a triple that had the casting busted around the nut due to trying to force it off... Stud was bent, too.
              • #8
                Got it. It was the one nut under the cylinder head. I head been separating from between the spacer plate and midsection rather than from between the block and spacer plate. Thanks
