fleet captain bil
- May 24, 2011
- 6
I am looking for guidance on what wires connect to the 60 amp charging fuse in the junction box of my 1963 Evinrude 75 HP electromatic shift. Color coding of wires would be appreciated if someone can provide. I know the fuse is mounts to the positive diode frame and one wire appears to go to the condenser mounted inside the junction box. What side of the fuse mechanism should the condender wire connect to? What other wires need to be attached to the fuse. Thanks in advance for your help. I dont want to blow the fuse at $30 a pop, and not easy to find.
