A while back i noticed gasoline leaking out from around all six of the carborators on my motor. The motor would still run fine once it got started, but it had become very difficult to start so i di a carb rebuild on it with new seals, floats, and pins. After this rebuild gasoline did not leak from around the carbs anymore and the engine fired right up. The problem is that when running it will only reach 4000 rpm at WOT and the top speed has dropped from around 65 to 45(the boat is an 18' stratos). The boat is stored 2 hrs away at the lake, but next week i will be going up there so would like to try and work on it then. What i need to know is things to try while there because i will probably not have internet so if you could help by giving me a list of things to try that might fix it, or help further diagnose the problem once i can upload my findings to here.
Thanks any help is greatly appreciated
