Re: 1990 Johnson 70 HP Compression
There is no "normal" compression, wcoates. Too many variables can affect the compression numbers. . .gauge, battery, conditions, technique. If all of those things affect measurement on one cylinder they will affect all the same amount and produce close to the same psi for all three unless one has a problem..
What we look for is all cylinders compressing within 10% of each other. The numbers you quote are very close and indicate a healthy engine.
