superflydudebike
- Jul 16, 2007
- 130
I have not used this motor for a few years as I upgraded to a 15 HP. I usally have been running it about once per year in a can, however. I was putting it away for winter storeage and ran it in garbage can, mostly above idle speed The exahust port was not spitting any water and the engine became heated quicky. I shut it down promptly. Is this a likely impeller problem or a thermostat issue? I looked at intake screen and that did not seem to be clogged. I read in a different post that it is difficult to get adequate water circulation running it in a tank in neutral. Should I try running it with cuffs? In can in gear? Any advice as to best problem solving steps? I have had this engine for about 6 years and impeller has never been replaced while I have owned it.
