divimon2000
- Oct 5, 2008
- 68
Apologize in advance - I'm sure this is posted somewhere but search and FAQ's turned up nothing for me. I cleaned the carbs and plugs on this engine that hadn't been run in a couple years. That corrected most of the poor running/idling issues (still stalls at low RPM, but that may be mixture/idle speed). Anyway, I have this mid-high RPM clunk like I'm hitting something! Happens maybe every 10 seconds. Below half throttle it doesn't happen. Sounds like a cluck but probably a miss? I'm assuming its timing and if it is, can i adjust with timing light and a screw on these engines? Any thoughts appreciated.
