I've got a 95' Evinrude 115 Crossflow Bubbleback that had a piston ring failure on the #3 piston. The ring broke and was pulverized before blowing out the exhaust. All the ports on the cylinder got knicked up but the exhaust side is obviously worse. I have attached a photo of the damage (had to resize hope you can see it). I am concerned about the damage to the exhaust ports and whether or not it can be repaired. Right now my plan is to send the block off for boring, nobody local will do blind hole boring. Any input on the damage and if it is fixable??
