I have a 1957 Johnson Seahorse 35 Hp.
Warning: I am a newbie to this
The motor has been sitting around unused for at least 20 years, and after having had it apart (it was surprisingly clean except for the LU), replacing the impeller, lower unit seals and bearings and cleaning the carb(although not done as thoroughly as recommended in the FAQ here) I tried starting it today. After a few pulls to my great surprise I managed to get it started, however after about 10 or 15 seconds the engine dies. I have new plugs and the compression seems to be very good, and when working it is firing on both cylinders
After further reading tonight, it would appear that I should replace the coils since it is so old and would likely be in poor shape, but would this be the reason for it to die like this?
Simon
Simon
