Welcome Guest - Sign Up today
No announcement yet.
1961 Evinrude 3 hp Lightwin Oil/Gas Mixture
This topic is closed.
  • 1961 Evinrude 3 hp Lightwin Oil/Gas Mixture
    Hey guys! I have a 3 hp Evinrude Lightwin and I need to know the correst oil/gas mixture.
    Thanks guys!
    Re: 1961 Evinrude 3 hp Lightwin Oil/Gas Mixture
    24:1 is correct ratio for that year of engine. Use TC-W3 oil.
    I love the smell of a two stroke early in the morning
    1970 Starcraft SS-V powered by a Johnson 85ESL70
    Get your copy of the CDI Troubleshooting guide here.
    http://issuu.com/cdielectronics/docs...owFlipBtn=true
    • #3
      So explain this to me in gallons - if I use 1.5 gallons of gas, how much oil should I use
      • #4
        1.5 gallons is 48oz. At 24:1 you add 2 oz of oil.
        sigpic
        • #5
          Some will run 24:1, but I actually prefere 16:1 in motors up to 10hp. 24:1 in 15hp or bigger. Many here run 24:1 without issues though.
          Admiral Zephyr
          1941 Johnson HD-20 (in restoration)
          1947 Sea King 5hp
          1948 Evinrude Sportsman
          1951 Evinrude Fastwin
          1955 Johnson CD-12
          1955 Johnson RD-17
          1955 Evinrude Big Twin
          1956 Johnson RD-18
          1957 Evinrude Big Twin
          1958 Evinrude Fisherman
          1958 Johnson FDE-12
          1959 Johnson RDSL-21B
          1974 Tanaka 1hp (screamin' drink mixer )
          • #6
            I'm with Zeph, I go at 16:1. For my figurin' I divide oz by the ratio I am using and that tells me how many oz to use (128/16=8)(128/24=5.3) etc.
            • #7
              Uh-oh, recalculating..... 1.5 gallons is 192 oz. so about 8 oz of oil is needed - 1 cup
              • #8
                Agreed 8 ounces of oil for 1.5 gallons of gas for 24:1. If you want to run 16:1 you need to mix 12 ounces of oil to 1.5 gallons of gas.
                • #9
                  To be very honest, the decals on that motor will say 16:1 (1/2 pint per gallon.) These motor are 100% friction and no needles at all. Oil is the cheapest thing you'll ever put in a motor. Why skimp on it?
                  It sucks that nymarine watermarked all their photos.
                  Admiral Zephyr
                  1947 Sea King 5hp
                  1955 Johnson CD-12
                  1955 Johnson RD-17
                  1956 Johnson RD-18
                  1958 Johnson FDE-12
                  • #10
                    Oops! My bad. Thanks, seahorse. Bad idea trying to do it in my head.
                    sigpic
                    • #11
                      The motor says 1/3 pint for every gallon. If I go by that, I am at 8 ounces (7.95) per 1.5 gallons of gas. Thanks for all your help guys! I really appreciate it!!!!!!!!!!!!!
                      • #12
                        for a 1969 Evinrude Lightwin 4Hp would the correct fuel:oil Ratio be 50:1?
                        • #13
                          Yes that's the official line. 1964 and newer use 50:1.
                          However these mall motors do not have needle bearings throughout so if heavily used are better run with a bit more oil.
                          • #14
                            One day you people will discover litres and cc like the rest of the world use.......... Doesn't half make calculating fuel mixtures easy!
                            • #15
                              going to liters and CC's is like a new pair of boots.... you curse for a while but eventually they fit around your feet and in your head
