Welcome Guest - Sign Up today
No announcement yet.
Trying to replace bottom Piston on a 1975 Johnson 75 hp motor need help...
  • Trying to replace bottom Piston on a 1975 Johnson 75 hp motor need help...
    I am trying to replace the piston on my Johnson 75 hp motor. The problem I am having is the front cylinder half will not come loose at the bottom . I have removed all the screws that I can see the top is loose but not the bottom . I can not figure out what is holding me back.. Is there something else I need to remove to get this off? Thank you
    Re: Trying to replace bottom Piston on a 1975 Johnson 75 hp motor need help...
    Have you removed the powerhead from the lower unit? If not, that needs to be done FIRST.
    There is also a seal retainer cap on the bottom of the crankcase that has bolts in both halves... Only accessible when the powerhead is off.
    [IMG2=JSON]{"data-align":"none","data-size":"full","src":"https:\/\/forums.iboats.com\/filedata\/fetch?id=9974593&d=1435747884&type=full"**[/IMG2]
    • #3
      Thank you so much this is what I was thinking after research .. Your help is much appreciated...
