Welcome Guest - Sign Up today
No announcement yet.
transom clamp screw/swivel plate fix??
  • transom clamp screw/swivel plate fix??
    has anyone come up with an effective,lasting fix for re-attaching the swivel plate (cup) to a transom screw??
    many men fish for years without ever knowing its not about catching one.
    Re: transom clamp screw/swivel plate fix??
    Yes, OMC did. It requires a special tool and the washer retainer of course.
    The alternative is to install the new type swivel clamp that incorporates a threaded hole in the center rear portion of the threaded shaft and a related threaded shoulder bolt to retain the washer.
    Exactly what engine are you speaking of?
    Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
    • #3
      have a couple with that problem, but the one id like to fix is a 1966 jw-21, i do have the original swivel plate
      • #4
        Look at the site below, different engine but same part, retainer #25.
        It does take a special tool to install it, maybe borrow or rent from local deal if they can find it.
        http://www.ishopmarine.com/ishop/jsp...ier-100-005-EJ
        • #5
          Private message sent.
          • #6
            I've put those retainers on with the right size socket before. Best thing to do is get the new style clamp as Joe suggested.
            • #7
              I just file the clamp bolt end flat used a small peen punch then drilled a hole tapped it and bolted on a cup, I'v done a few this way and never had one fall off yet, I do put a dab of thread lock before bolting on the cup,
              • #8
                Another good idea. No kidding.
