70hp vro evinrude need help with wiring!! HELP!!
boobie
Re: 70hp vro evinrude need help with wiring!! HELP!!
Could you post a pic of all this ??
Evan.t
ArCObBiCIAAiOVO.jpgArCOmQ_CAAIygDM.jpgArCQ0h6CQAIhC7a.jpgArCQ8ZvCMAQgdCl.jpgArCQdx7CAAI8lit.jpg
boat
Evan.t
boat
Evan.t
boat
Evan.t
boat
Evan.t
boat
Evan.t
70hp evinrude vro wiring hookup please help!!
boat
l.ArCObBiCIAAiOVO.jpgArCOmQ_CAAIygDM.jpgArCQ0h6CQAIhC7a.jpgArCQ8ZvCMAQgdCl.jpgArCQdx7CAAI8lit.jpg
Evan.t
Re: 70hp evinrude vro wiring hookup please help!!
Daviet
I don't have a factory manual for your engine so I cannot help you out.
I have never been able to find any manuals online for free, probably because of copy write laws.
Is there any way you are able to order a factory manual?
Maybe someone with a factory manual will come along and be able to help you out.
Evan.t
boat
Evan.t
boat
Evan.t
boat
trendsetter240
Does your power trim and tilt work? Most of the wires you are looking at are the power trim switch and limit switch wires.
Home Cookin'
I have that same motor, my second mid-80's 70 hp. Like often happens with old motors you buy used, you inherit all kinds of misteries from previous owners, and all kinds of unreliable info. For example, don't be too certain on your year--I think it may be an 86 but I'm no expert; they changed the motor around 86-87. And it may be combination. And the year it was first sold is sometimes a couple years after manufacture.
Don't worry about the open plug.
Many wires are old temp sensors, PTT connections, etc and have been bypassed--like your VRO was (mine was taken off, too).
I put a new wiring harness on mine; it was not cheap for that model.
A wiring diagram from a manual may be helpful but again if your year is off or it's been altered, it might not do you much good.
"No spark" makes me wonder if your safety cut-off lanyard switch is your problem--if it's hooked up, you may still have a defect somewhere along the line.
The hot wires with the corroded ends need to be address first--they power something.
Here's a website that may be helpful http://www.outboardignition.com/
I'll look around and see if I have a diagram somewhere in the garage.
trendsetter240
They are the power supply for the power trim and tilt. Those two black squares you see them connected to are the up and down relays for the trim.
Evan.t
boat
trendsetter240
The lanyard is the coiled red cable that connects to the throttle control. It slips into the side of the control box. If it is not connected there is no spark.
also, how do you know you need a new trim pump? None of the wires are hooked up so it wont work. I'd test it first before buying a new pump.
Evan.t
boat
trendsetter240
The lanyard is a safety device. One end clips into the control box and the other clips onto your lifejacket or belt loop. The purpose is that if you are knocked out of your seat (or the boat) the clip pops out of the control box and stops the motor.
