,I have a 1999 Johnson 25 hp 3 Cylinder,,I bought this used late last season on a Carolina skiff,before I put the boat in,I put complete Brand new water pump in,old one was shot,also seen the thermostat assembly was mising,put a new Thermostat and assembly unit in,check compression in all 3 cylinder warm up was 105psi ran motor for a good hour every thing look and sound good motor started on the first turn,,put it in the water ran for about 15 min easy just got over half throttle and bang sound happen,started missing running rough at this point if I went over ? throttle it would shout off,then hard to start, Idle back to the dock,a guy at the marina said the motor was shot,,that he could have it rebuild,ouch, hi Dollar,,,I know car engines have rebuild a fue,just don?t know these 2 strokes,today I just put it on the hose and ran it for a hour sound good started first turn,check compression still 105 in all 3 cylinder no hesitation with the throttle,,would appreciate any HELP,,is there something I?m missing,or need to check,,,,I just never seen a motor with good even compression and spark and fuel and start on the first turn, Be Bad Thank You
