maineboat
- Aug 15, 2011
- 50
Wow!! I am so impressed with all the information on iboats, that I just have to start a thread so others can follow and perhaps benefit from the progress on my rebuild.
A little history:
I purchased a 1986 Starcraft SS-160 Series SL, bow rider for $500 back in October. The motor was in boxes.... I was told that the engine had a blown piston, damaged head, but the crank was OK. The exterior of the boat is immaculate, but at least some of the interior will need to be fixed. The floor has a large spongy spot in it.
He said that I should be able to bore out one cylinder, replace the head and be good to go. Well, after review and math, I've decided that a complete rebuild is more economical and less risky than just doing the one piston. I also found that the top bearing was very "gummy" and turned with some difficulty. The crank does appear to be OK, no scoring, scratching or discoloration. I will mike it later. Only about $300 difference and I will have a "new" motor. I also discovered 4 broken bolts as I looked everything over.
The PO did do a good job with disassembly; everything is marked and grouped in Zip-Lock bags. He also gave me a OMC parts book specific to my Motor, and a Clymer repair manual. Not as good as the OMC book, but it will do. I am not a novice.
A little history:
