Mendelivium
- Nov 27, 2011
- 3
I just bought a rebuilt lower unit for my Johnson 150 XP motor. I have never worked on boat motors much but I got the old one off and the new one on. While doing so, I saw that the rubber seals for the exhaust tube were looking pretty bad but I put them back any way. When I ran the motor with the rabbit ears, I noticed water coming out from that area (exhaust tube area) where the lower unit meets the rest of the motor. Do I need to worry here? I am trying to understand the where water goes in the lower unit in general. Water must come up through the exhaust - right ? Does water normally surrond the water pump housing and shift rod housing ? In other words, where all is the water in the lower unit normally? Are the seals for the exhaust tube there to keep water out or the exhaust in ? If water is leaking from the exhaust tube, there will definitely be water around the water pump housing, etc. Is that normal ? Ok ? Thanks for your input and hope you all had a great Thanksgiving !
Oh also, is there normally any kind of seal between the upper motor and Lower unit ? I saw none on my old lower unit.
