ccarlson2004
- Aug 4, 2011
- 8
Hey all, I have a problem I'm hoping you guys can help me fix. My #1 piston has made contact with my spark plug the last 2 out of three fishing outings. It doesn't happen right away after firing, it will just happen out of no where, I'm not even sure if it happens at full throttle or less. I checked the other 3 plugs and they are fine. Plugs are less than a year old, and are all identical. I've also noticed that the piston has a small check mark from hitting the plug. Any suggestions?
