Welcome Guest - Sign Up today
No announcement yet.
Fuel pump, ethanol, teflon tape
  • Fuel pump, ethanol, teflon tape
    I took a break from stripping the hull of the holiday this weekend. We wanted to hit the water for some bass in the Cajun but had to take care of the fuel pump issue on the 1995 88 spl. Classic symptoms. Primer bulb would not pump up. Would not run at throttle without pumping the bulb. Poor idle/performance. After removing the pump and dissembling I found the following. In addition to being worn out in general.
    Diaphragm spring out of place
    Click image for larger version
ID:	7150628Click image for larger version
    Deteriorated valve, assuming from ethanol
ID:	7150630Click image for larger version
    sigpic
    Re: Fuel pump, ethanol, teflon tape
    More photos
    New valves on bottom
    New valves installed
ID:	7002276Click image for larger version
    sigpic
    • #3
      Teflon tape in the filter. Some has been broken down by the ethanol.
      New fuel line with ethanol resistant liner.
      The motor sure runs fine now.
      P.S. didn't catch any bass.
      sigpic
      • #4
        Looks like a job well done, good fishing.
