trombonecooter
- Apr 14, 2009
- 14
i recently replaced an 86 110hp evinrude with a 79 johnson. The first thing i noticed is that the 79 motor does not have a water indicator installed. Is that something that can be easily added to the motor?
I am also using the same control box and wiring harness as i did on the 110 evinrude. There is a grey wire in the harness for the tach pulse, but is that wire actually connected to anything on a 79 Johnson?
