88seville100
- May 16, 2009
- 47
Ok heres a little background first. The motor is an 87 225. E225TXCUB. So far I have replaced head gaskets, fuel pump, fuel water separator, and rebuilt all 6 carbs. When I bought this boat about 2 months ago it wasnt running at all. So I did all these things to get it going. Now it runs, just not very well.
I can get the engine started pretty quick, and it will idle great all day. If I rev it in neutral it also sounds good. Then I put it in gear and take off. It does ok in the low rpm, but then when I put the throttle down it takes off like it wants to go to redline, but then will get stuck around 3500 or so and slowly start to come down in rpm. If I leave the throttle all the way up it will start to surge. The rpms will drop and try to pick back up. Then after a little of this they will just start to drop more.
Then if I let it run at low rpm for a little more I can floor it and get it back to around 3500. At one point it almost hit 4000 before it started dropping again.
Do you guys have any idea what this could be? I dont think its the fuel system as just about all the components are brand new.
