Ive recently purchased a '67 Johnson 9.5 to try to upgrade the power to my 14' Alumacraft as my '76 Johnson got it up on plane but didnt get any speed. So I picked this little 9.5 up for under $300 but the compression is down at 75psi in both cylinders. So after searching the forum here I read about trying a decarb. I just did it today and followed the instructions exactly as it was posted on here and the compression didnt come up at all. This 9.5 pushes the boat ever so slightly faster than my 6 horse but the difference was almost unnoticeable. So my question is, A: ideally for the age of the motor what should I expect the compression to be, and B: Other than the lack of power (I could be wrond, but I feel that way) it purrs like a kitten from idle through wot, so should I susect the culprit rings, and cylinders? and C: I can't seem to find a source for the breakdown manual, any siuggestions?
Thanks in advance!
Thanks in advance!
