Welcome Guest - Sign Up today
No announcement yet.
Can I convert my 55 fastwin to remote steering and throttle?
  • Can I convert my 55 fastwin to remote steering and throttle?
    I have a 1955 fastwin 15 Hp and curious if these engines are capable of converting to a side console with throttle control on the steering colum? Tired of using tiller handle, any info will help thanks!!!
    Oside por vida
    Re: Can I convert my 55 fastwin to remote steering and throttle?
    Yes, those motors are set up for remote controls.
    Admiral Zephyr
    1941 Johnson HD-20 (in restoration)
    1947 Sea King 5hp
    1948 Evinrude Sportsman
    1951 Evinrude Fastwin
    1955 Johnson CD-12
    1955 Johnson RD-17
    1955 Evinrude Big Twin
    1956 Johnson RD-18
    1957 Evinrude Big Twin
    1958 Evinrude Fisherman
    1958 Johnson FDE-12
    1959 Johnson RDSL-21B
    1974 Tanaka 1hp (screamin' drink mixer )
    • #3
      How would I go about doing this? If I where to buy used stuff off craigslist how would I verify if it is compatable?
      Oside por vida
      • #4
        Well, is your boat set up with steering by chance? If not, then you have a bit of a project on your hands there. You can either set it up with the older cable and pully system, or the later style. I'll post ya some pics of some examples in the morning, if someone doesn't beat me to it tonight.
        As far as the throttle and shift cables go, that's the easy part. Any OMC twin stick/twin cable shift box set up will work on that motor. It would be best to find the older Johnson Shipmaster or Evinrude Simplex Shift box set.
        Admiral Zephyr
        1947 Sea King 5hp
        1955 Johnson CD-12
        1955 Johnson RD-17
        1956 Johnson RD-18
        1958 Johnson FDE-12
        • #5
          The OP is probably asking how the cables attach to the motor. He will need the two cable locks. Called "brackets here", but "locks" in the parts lists)
          • #6
            Yes, take a look at fig. 8 and 12 on F_R's attachment and you'll see the brackets that the cables hook up too. It's a good possibility you motor may have them on it already, but maybe not. They should be readily available at your local marine dealer. I believe they were used on virtually every OMC from 1953 - 54 on. Any motors with the roto-grip throttle were set up to take them.
            The link below is pretty much what your shifter set up would look like, but for your motor, it would be a better match to find an earlier set up. This box would work though.
            http://cgi.ebay.com/ebaymotors/evinr...m19c2281ee4#sf
            You could try any of these salvage yards and one of them should easily be able to help you.
            sea-way.com
            engine blade and prop.com
            outboard-parts.com
            laingsoutboards.com
            tcoutboard.com
            fairwindsmarina.com
            salvagemarine.com
            marinepartsoutlet.com
            outboardexchange.com
            Superior Marine (800-338-9281)
            budgetboats.net
            americanoutboard.com
            piratemarinesalvage.com
            trixieslanding.com
            mmmarinesalvage.com
            tcoutboards.com
            Good luck, I hope this helps.
            Admiral Zephyr
            1947 Sea King 5hp
            1955 Johnson CD-12
            1955 Johnson RD-17
            1956 Johnson RD-18
            1958 Johnson FDE-12
            • #7
              Very helpful thanks! What's so hard about doing the steering?
              Oside por vida
              • #8
                Well, that depends on that kind of a boat you have. Is your's just an open boat, or is there a steering set up already there?
                Admiral Zephyr
                1947 Sea King 5hp
                1955 Johnson CD-12
                1955 Johnson RD-17
                1956 Johnson RD-18
                1958 Johnson FDE-12
                • #9
                  Here is a good post to give you an idea of setting up your motor for steering.
                  http://forums.iboats.com/showthread.php?t=454007
                  Admiral Zephyr
                  1947 Sea King 5hp
                  1955 Johnson CD-12
                  1955 Johnson RD-17
                  1956 Johnson RD-18
                  1958 Johnson FDE-12
                  • #10
                    Here, I borrowed this photo from another thread.
                    Steve.
                    • #11
                      Hi. Check out "Miss Peachtree". I bought the boat already equipped with remote steering. I am very happy with the lack of a set of pulleys at the outboard. It steers like it has rack and pinion steering on a sports car, quick ratio!
                      Take the tension spring and 45 degree interference thing out of the tiller handle. I believe that's there so the speed doesn't go back to slow if you momentarily loose grip on the tiller.
