I inherited a decent older boat that has a Evinrude 140hp VRO 1986 outboard. The motor runs and compression is ok. I drained the gear case tonight and the first thing that came out was clear water about 1/4 of a cup. Then black tar like oil and water mix (about 1/2 a cup) and then mostly black gear oil. The little magnet on the bottom screw has a few small pieces of metal dust like stuff on it.
The motor was not serviced in a long time, and last time it ran in the water was 4 years ago. I was started 2 years ago out of the water just to check it. I took the prop off and inspected the seal underneath it all looks fine. I put 1/2 a quart into it and re-drained it to try and clean it out and the refilled with fresh Hi-Vis oil.
I have the service manual and I?m ready to break it down if needed just haven?t run into this one with my other outboards and this is the biggest one I have owned.
My questions are below thanks for any pointers:
1.Is the amount of water possibly due to condensation from sitting for so long ext. is it normal for an older motor with 300 hours to have a little water in the gearcase?
2. Should I go run it and drain it and look for more water or could I cause more damage i.e. is what I stated above an absolute indication of a bas seal?
3. If it?s a bad seal what seal is the likely culprit - what should I look for when I break it down?
Thanks for any help.
