Unfortunately the answer is no, continue to check on ebay they do pop up from time to time, also
www.screamandfly.com the racers are always replacing the OEM with solid mounts (which I do not recommend) however they do post the OEM's up for sale. Good luck and keep us posted.
If you going to replace em do one side at a time, you may have to use heat be careful not to over heat it .. I use a little propane torch from Home Depot. The job is more time consuming not brain draining
Tip, Wait until the replacement arrive this way you look at it and have a clear understanding what you are dealing with and how it is mounted etc...
